pillsy
- Joined
- Apr 20, 2010
- 31
Well Here is the story. I have a 1973 Century Raven 17 with a Mercruiser 140. Just got it started for the first time this year. I fired it up it ran for about 5 minutes, then started to run ruff. I turned it off and pulled the plugs. Yup water in the #4.
I hooked a water hose to the thermostat housing.Then pulled the exaust manifold away from the head about 1/2 inch and turned on the water to see if the manifold was leaking water into the intake or exaust, nothing bad there. Next turned the water pressure up and checked to see if the water was either making the oil level rise or if it was going into the cylinder via a hole in the head gasket. Nothing there either. The only way I can get water to go into the cylinder is with the engine running. I think (hope) its just the head gasket. Can anyone tell me if there are other ways to check for other problems. I don't think its a cracked block, but I don't know for sure. any advise would be great.
