water inlet direction?
badman
Hi all.
Don't know much about the directional flow of water in an inboard/stern drive system so...
Based on the hoses available and inlets and output ports on my engine and manifolds...
does water come in the two water hoses at the top of the stern drive (through the stern drive moulding somewhere?), into the exhaust manifold (wet cooled type), out of the manifold, into a splitter / combiner part on top of the engine, into the water pump and out through the transom?
Or the other way... (i suspect this way due to location of pump in sequence).
In the transom to the water pump, through the engine water jacket and splitter unit (whatever that item is..) through the two hoses into the manifolds, out the manifolds via the two oses into the top of the stern drive?
Until i can fire the engine up i am unable to test the direction etc.
Managed to remove the manifolds yesterday and was pleasantly surprised to see that the are steel, not cast iron so can weld them. Only one needs repair. Badly however. Should be a doddle.
Managed to turn the engine over by hand and on the starter motor (not iginition), just to see if seized and turned well. (after 8 years!)
Rewired the electrics and replaced a few relays to the stern drive and managed to get it to tilt up and down on a new switch.
Managed to enable magnets in stern drive to control forward and reverse gears. (12 volts accross relative magnet/gear)
As soon as i can work out nthe water direction i can continue restoring that system.
Engine is inboard V4 OMC stringer stern drive.
Many thanks all
matt
Re: water inlet direction?
Ayuh,... That's how a Normal system is plumbed...
The What's-cha-ma-call-it is the T-Stat Housing....
chiefalen
Sir; may i suggest that you buy a manual for the drive, and the motor.
The drive i am confident in posting is a electric shift model long shaft model.
The motor i have never seen in a boat, and in my humble opinion of a European design.
I have seen the pictures, of the drive and would be happy to help you, if you would be so kind as to post close up picutures of the drive.
Please be aware that you cannot start the motor without water going to the drive, even for 1 minute, because you will distroy the impeller in the drive.
I would also suggest you replace the impeller before even trying to start the motor.
I would if it were my boat change the outdrive oil. And check the ball gears for wear.
There is 4 different places to change oil in a electric shift stringer drive.
May i ask if the tilt works on the drive if not here is a link that i wrote some time go.
http://forums.iboats.com/showthread.php?t=259807
I am currently on vacation and will be home, in a few days, with access to my home computer with other links, that you may require, please keep us informed of your progress.
You may need to change the transom boot, and i have links to that also at home.
One last thing, i have some parts, that i have no use for that came off a electric shift model, that you may require. And i feel this is where i would like to see them used, in a worthy restore.
Good luck !
