I have a slow water leak seems to be coming in a small hole just above
the drive shaft coming into the boat.its a mercruiser with a Alpha 1 drive
my mechanic said water can't come in the boat through the drive shaft
bellows??but it seems that the small hole is in the same area as the bellows
I will add about a week ago I drop my boat off the trailer at a boat launch
onto the grass not a big bang but a good thump took the boat on the
water after it happened everything seemed ok untill the next time out
then discovered a small leak.
Any thoughts???
Thanks Lee
Any thoughts???
Thanks Lee
