Water pump impeller
wlg
I just replaced the complete water pump on a 125hp. I did not use the manual and am now wondering if the impeller is folded/bent in the wrong direction.
My question is - Will the impeller return itself to the proper direction when the engine is turned over or should I take the unit back apart?
Also, the manual shows a stop, rubber boot and a collar at the top of the drive shaft. I did not find a collar. Is this a problem?
Year of motor is 1986.
BonairII
Re: Water pump impeller
I think there should be a rubber O-ring that fits in a groove on the shaft.
