Biglabsrule
Thread starter- Joined
- Oct 2, 2008
- 8
I recently bought a 53 evinrude 15hp and got it going pretty nice today. It had a problem with the water pump and i tore the bottom end apart the other night. The gasket between the top impeller housing and the verticle tube was pretty ratty so i put some 100% silicone to it.
Like i said got her going earlier today and she does pump but here's the story... when i take the water drain plug out it shoots pretty good little stream, but when running the discharge port doesn't appear to have all that much water exiting. The hole is roughly 3/8" but deff. isn't close to half that flow.... this is my first outboard... is that an adequate flow of water... the head seems to be pretty cool, can dribble a bit of water on the head and it stays but just thought it should have more water going through?
what do you pros think, thanks in advanced i'm sure you guys have some advice... travis l.
