Water pump options to replace obsolete impeller
sam60
Re: Water pump options to replace obsolete impeller
You may have just found the culprit to the seized engine you started with.
It was fine after rebuild and prior to 5 run hours on the lake. Took it out and lubed it up with Vaseline (the impeller) prior to first splash. It's a dry desert out here and rubber type products don't do too well. This is a bummer.
sam60
I could use some advice on the 3-component conversion to eliminate the original impeller setup. I have found a variety of water pumps and thanks to a friend, a nice sea strainer but I do not have a good way to facilitate the installation of a hull intake fitting without pulling the engine again. I've searched for a transom intake that will pull water at plane but no luck. Any ideas? Thanks
HT32BSX115
Mike,
I found the following: www.boatfix.com/merc/Install/gas/86017211.pdf
It's Mercury install instruction but it will work. (Page 17)
It outlines 2 types of sea water pickup. Thru-hull and transom mounted. I don't know if the transom mounted pickup is a Mercury part but a Merc dealer should be able to hook you up.
regards,
Rick
sam60
I am about to pull the trigger on the Mods for the water pickup. I would feel better by running it past all of you first for any warnings to what I am about to do.
1. MERCRUISER MERCURY QUICKSILVER WATER PICK UP 88845A1 (No room to access through the hull)
2. San Juan sea strainer - 1-1/4"
3. A yet to be selected pump from Michigan Motorz. (Sherwood P-105 maybe.)
Any advice is appreciated.
sam60
I often Marvel at the drawings that are provided here by members to help give a visual to the instructions. In an attempt to visualize my previous post for the cooling system modifications, I offer the drawing below. I did not have access to the full adobe software from work, so I used some old software at home called Dixon Ticonderoga (Version HB). I tried to install the updates, but couldn't find the patch (power cord for sharpener). Anyway here is the installation drawing. Any advice is appreciated.:D
View attachment Scanned055.pdf
mrapala1
do not cut the hole, I purchased a bayliner a while back it has the king croba /460. inside the cabin i found a box of spare parts with 4 new impllers if you still need one send me an email. hate to see someone have to cut a hole in a good boat.
sam60
Thanks mrapala! PM sent.
Those may be part number 983895. Mine would be 987176 or 3854072, probably different. I actually had a good day today and found 3 !
bigike
I've read on Offshorerry, they are cone clutch friendly... HAAHA There is a guy there with a blown 454 that simply installed a volvo raw water pump, just remove the old impeller... and let her eat. Not one problem in what i understand as years of hard service.
Glad i bought 3 and one full kit! Note that the engine is a "GL" it's a volvo :)
HT32BSX115
Try Jody at Sea-Way.com
Larry E
Yeah. I mentioned them back in post #17 in this thread :rolleyes:.......... Seaway wants $135 for an impeller that originally retails for $39.
I wonder what else they're ripping people off on........
