sam60
- Joined
- May 21, 2011
- 3,189
Re: Water pump options to replace obsolete impeller
It was fine after rebuild and prior to 5 run hours on the lake. Took it out and lubed it up with Vaseline (the impeller) prior to first splash. It's a dry desert out here and rubber type products don't do too well. This is a bummer.
You may have just found the culprit to the seized engine you started with.
