1989 Engine 5.7 mercruiser inboard with Alpha 1 outdrive. With the muffs connected to the water pickup and the engine running, should i get a lot of water going to the engine or jUST A TRICKLE. i removed the hose off of the white tube that come from the water pump to the engine and noticed that i only had a trickle. I have a problem with this engine over heating, i also found that someone removed the <br />T-Stat, I had a shop install a new water pump two months ago when this first started, man i just put 1200.00 in . and still a cooling problem. The bright side is , the engine runs really well.
