I have a 1958 Evinrude 18hp motor and I got it finally run after 20 years of sitting. I ran it for a few minutes, and the engine got extremely hot, I don't know if this normal for this motor or not. The crankcase was hot to the touch<br /><br />I checked the water pump and noticed it is jammed in there pretty good, it looks OK, and there is a few rubber shavings inside the housing.<br /><br />I noticed that the water pump housing is a oval shape and that you need to wedge the impellar in there, is this normal or is there suppose to be some play in there?<br /><br />I thought the water pump was working with some gurggling in the test tank, but don't know if that is exhaust or water? is there a way of testing to see if it works?<br /><br />Also the water pump I have is like a soft rubber.<br />is that normal too?<br /><br />I was told the water pump was replaced about 10 years ago and haven't been run since.<br /><br />Thanks for looking!
