Ok, I just installed a transducer for a new sounder, and when I drilled through the transom, at the bottom a bit of water came out, but there is no acess to this area from inside, in the back where I can see the bilge its only a little small spot at the back, and has no drainage holes to the other parts of under the floor, looks like maybe someone galssed it in? I'm sure the transom wood is fine, when I drilled through, nice wood curls came out, no rotten wood came out with the drill bit. Am I ok to drill some drainage holes???? What to do, I don't like the water in there where it cant get out?
