ctravis595
Thread starter- Joined
- May 10, 2013
- 50
i have a weird issue with my (i think 1988) johnson 48 spl. i bought the boat used and i'm thinking the previous owner couldn't get this issue sorted out, explaining why he wanted to sell the boat
he said he replaced the impeller already, so i don't think the engine is getting overheated at all. it shoots a steady and strong stream of liquid
but whenever im out on the water, i start the boat and it usually needs a little throttle to stay running under load. i don't have a tachometer so it's hard to know exactly whats going on with the rpms. it idles, but if i dont have some throttle going then it will die when i put it in gear
it will run for a while (at least 15 minutes) at full throttle, runs great actually and i was somewhat impressed with the speed this little old 48 hp can get to with my 17 foot center console but after running full throttle for a little bit it will start to run really crappy, like it's only firing on one cylinder instead of two and only barely idling along... sometimes i can get the boat to kick back up to full throttle after a few minutes of playing with the throttle. pumping the gas bulb doesn't help and niether does spraying starting fluid in the intake
i tried taking apart the carbs to see if i could find anything that looked wrong but everything looked okay? i did my best to clean them out and blow out anything that could be clogging it up but it didn't really help
i've noticed non ethanol gas helps it run better/dies out less
i'm assuming my issue is my high speed jet carbs, my question is - should i just buy a rebuild kit or a whole new carb assembly? i'm new to working on these outboards but they seem extremely easy compared to working on my cars and bikes. how do i know exactly what parts i need to order for my 48 spl?
any help is awesome and would be greatly appreciated!!! would be cool to get the boat running for summer!
