drewpster
Thread starter- Joined
- Oct 17, 2006
- 2,059
I had to drill my drain for my splashwell at a downward angle. I intended to use a brass drain tube to seal and finish the hole. The flange of the drain tube will not sit flush on the outside of the hole because of the angle at which it is drilled. Any ideas on how to put some sort of drain tube in this hole? Simply glassing the hole is not an option because it is already in finish paint and I do not want to buy more. I considered buying an extra length drain tube, cutting it off, and hand forming the flanges. But my metal working skills are about as good as my typing,,,. I also considered using epoxy to glue in a PVC tube, but i wonder how that is going to look. Any suggestions?
thanks, drewp
thanks, drewp
