what color is gear oil??
cparker072
Im leakin a real like milky sludge coming from behind the prop what is this and what needs to be done to fix it
oldrudedude
Re: what color is gear oil??
Gear oil mixed with water will appear milky. Do you mean the oil is leaking from somewhere forward of the prop or from the exhaust opening at the prop? Is it leaking fronm the lower unit drain plug?
Better check the lower unit oil for milkiness.
WIMUSKY
If you pull the drain plug and it looks milky, have the whole lower unit resealed.....
cparker072
where is the drain plug i just got this boat and dont know much about outboards i have an 86 70 hp its coming out both sides
cparker072
does a mechanic have to do the resealing or am i able to do it or is it better for a pro on this one
WIMUSKY
Judging by your responses, have a mechanic reseal it. No offense... The drain plug is a screw/bolt located on the side of the lower unit below the gearcase(driveshaft) housing. Use a screwdriver and unscrew it until some oil starts leaking out. May have to use quite abit of effort to break it loose.
cparker072
Alright i know where your talking about how much does something like that run
Is this something that has to be dont right away or can the boat be takin out for cruise
cparker072
its leaking from the exhaust opening and from the sides of the prop
WIMUSKY
Boy, I can't remember. I had a 18hp Evinrude resealed by a guy who worked out of his house right b/4 I sold it. He had been working on Johnson/Evinrude's solely for 30 years. I "think" it was less than $100. $75 maybe. I just don't remember, sorry.
As far as using it now. If the oil is looks like coffee cream, I would fix it first to be on the safe side. The oil will mix with the water so you shouldn't have a catastropic failure unless it leaks so bad that you drain out pure water too. I guess I wouldn't take a chance. A reseal is alot cheaper than a rebuild....
