what do you all think of this fish finder ?
jim phillips
Eagle Cuda 168 EX Fish Finder<br /> <br />The new Eagle Cuda 168EX gives you so much fishfinder power for so much less! It features a big LCD display and a built-in water temperature sensor. <br /><br />Description <br /> <br /> Display<br />4.5-inch (11.4 cm) diagonal screen <br />Film SuperTwist LCD <br />High-definition, 168 vertical-pixel resolution <br />Backlit screen and keypad <br />4-level grayscale<br />Sonar<br />Depth capability to 600 feet (183 m) with 800 watts of peak-to-peak power <br />High-performance, low-profile 200 kHz Skimmer transducer with built-in temperature <br />Wider fish detection area of up to 60-degrees with high sensitivity settings <br />Operates at boat speeds up to 70 mph <br />Advanced Signal Processing (ASP) automatically adjusts your settings for the best sonar picture <br />Patented Grayline separates fish from nearby structure and bottom <br />Advanced Fish I.D. shows underwater targets in different sizes of fish symbols <br />FishTrack displays target depth readings above fish symbols <br />Surface water temperature readings come from a built-in temperature sensor in the transducer <br />Zoom with bottom tracking and easy zoom-in/out control<br />Performance<br />Easy to connect and disconnect with uni-plug cable connector <br />Internal back-up memory for key sonar settings <br />Completely sealed and waterproof, even for use in harsh saltwater environments <br />Full 1-year warranty
rickdb1boat
Re: what do you all think of this fish finder ?
Good unit!! Go for it!
bubbakat
jim go for it it is built by lowrance technology
Boatist
Lucky Jim<br />As long as you do not belive all the numbers then can be a good low end unit for you. Lowrance and Eagle make high quality units. Just be aware the up to 60 degree transducer is a 20 degree transducer. The 600 foot depth is really about 100 feet in salt water if you want to see fish. The 800 watts peak to peak is 100 watts RMS. Still for bass fishing in shallow water unit would be fine.<br /><br />As a example my Lowrance unit specs is for 3000 watts peak to peak and 1000 foot depth and a 20 degree transducer..<br />However in salt water will not see bottom fish at over 200 feet. Yes you will see the bottom but no fish. With a 8 degree transducer can see fish to out to almost 350 feet.<br />I do not like the way they over rate everything. For me I want the true specs. <br />As a example they say up to 60 degrees transducer, Well that is a plane 20 degree transducer.<br />The industry standard is to rate transducers at the half power point or -3DB and there transducer is just that 20 degrees at the half power point of -3db. Look in the accessories and you will see no 60 degree transducer but instead all 20 degree. Now if you rate that transducer at the 1/10 power point it will be close to 60 degrees. Problem is to see fish at the 1/10 power point you would have to turn the sensitivity up so far to see that the screen would black out due to the return in the true cone angle of the transducer. I just do not like companies that are not giving you the real number.<br /><br />Anyway having said that still one of the best brands. But if you want to see Bottom fish or rock fish out in 300 feet of salt water you need at least 3000 watts of peak to peak power (375 RMS) and a 8 degree transducer. 50khz units work better in deep salt water than the 200Khz units.
