What does this switch do.
gooders
Being a relative novice when it comes to boat engines.On my 4winns I have a toggle switch on the dash that has the letters ACC under it.Anyone know what it does?:confused:
bijou22
Re: What does this switch do.
It stands for ACCESSORY and is a spare switch you can use.
180shabah
ACC is accessory, you may or may not have anything hooked up to it. I had two extra switches on my dash.
gooders
Well I never. Thanks guys really appreciate that. Maybe you could help me out with this one.Also on the dash is a switch which is basically a spring loaded push button set up.I thought it may have been a kill switch but when I looked underneath at the wiring its not connected to anything.Any ideas.:confused:
Don S
Horn?
gooders
Unfortunately not.The horn is on a separate switch.
bijou22
If its a kill switch, it should be more than just a button, something has to keep the button down. Does it have a groove in it or something similar?
180shabah
The P/O could have had anything hooked up to it. I wouldn't worry about it.
chappy190
What year and model do you have? Look at what accessories were available that you don't have. It's probibly for that.
Ayuh,...........
Probably a Spare Horn Button...................................
