what I should inspect? buying a use outdrive!!!
betayv
hello there and thanks again for help Im buying a used outdrive is a alpha one generation II, outside looks great, the ujoint looks great too, not signs of rust, the gear oil was clean, anything else I should check, by the way Im buying I used transom assembly from same guy looks clean what I need to inspect thanks again for any help.
Re: what I should inspect? buying a use outdrive!!!
Ayuh,... There's not much to See without a tear-down,... just roll the dice,...
Good Luck...
bigskiohio
spin the pop in both gears
robjen1019
check oil plug, if has magnet look for metal residue. Could bring a pressure tester and do a quick pressure check.
45Auto
Pull the top cover (3/8 12 point socket, 4 bolts, takes about 2 minutes) and look at the condition of the upper gears and bearing. If it's been sitting there with moisture in it they'll be all rusty.
wca_tim
even it the above... you're pretty much rolling the dice. that being said, the lack of signs of neglect on the outside... is a good sign that it has probably been taken care of.
I just bought a used drive sight unseen from someone in Michigan and it worked great this weekend on the river!
TilliamWe
Banned
I really hope you are not paying very much money at all. Because a Brand New (with a 3 year warranty) drive from SEI is $1395.
wca_tim
Just a week or so ago I bought a new SEI upper instead of even looking at buying a used drive. for the cost of the SEI units, I would only buy a used alpha drive if the price was right and it looked to be in pretty good shape.
The one I mentioned that I bought used from the guy in Michigan was an alpha one ss drive - not available as an aftermarket...
