What is a spark tester?
dew2
I read reference to a spark tester that states, set it for the spark to jump 7/16s inch.
What is this tester and where can I get one reasonably priced? I also read they can be got for as little as $7.00. Thanks!
ralphl
Re: What is a spark tester?
just ask the wife to "hold this" and crank er over . distance she jumps directly proportional to the intensity of the spark.
jasper60103
Yep, every outboard owner should have one. It's used for testing the ignition spark. Any auto parts store should have them.
shoestring
mine is the thingy in my elbow that rips my hand off the wire when i get bit. your sounds to be more accurate, no way of measuring with mine unless you measure the blood that leaks if I snag on something sharp on the way out.
jasper60103
Thanks tx1961 at least you have the knowlege to answer the question! with a fine example, I ordered one.
Sounds insulting and unappreciative to others that tried to answer your question.
dew2
Only honest ! He was the only one to answer and wasn't being comicial HaHaHa
saumon
Dont want to look rude, but did you ever heard of Google?
dew2
I have a spark tester,it cant be set to different widths.I did heard of google, just googleing spark tester didnt get me one with variable jump settings.Now with help here, I didn't have to search any further, Maybe I should google comedy!! See if they heerd any jokes?
