What is the best type Brake fluid for hydraulic Disc
Boatist
Fo hydraulic DISC Surge brakes is it better to use DOT 5 Brake Fluid, DOT 4 or DOT 3?
JCF350
Re: What is the best type Brake fluid for hydraulic Disc
Dot 5 is silicone based and probably not compatible.
The best is what the manufacturer calls for.
Boatist
Thanks for the replies. I have the Tie down disk but have a atwood actuator that came with the brakes from Champion Trailers.
I do not recall Tie Down saying Dot 3 but that is good infomation.
I just went out and checked the actuator and it also has stamped into the metal to use DOT 3.
Thanks.
