Re: What is this pipe down the center line ? 87 Bayliner
Did that area have foam in it? Regardless it is used to move water to the transom so it can drain out. My Bayliner has a storage area in the middle section of the floor, no pipe, but I have an I/O and there are small pipes (size of your finger) in the front and back of the storage area. There should be holes in the pipe to collect the water and allow drainage. Unless this attaches some of the front storage bins to the transom, can you send a pic the other direction? Where does the other end go? Some boats this was cardboard just to hold the shape until the glass was laid up, saw this on a 70's Starcraft I think. PVC should be okay but I don't know about adhesion when you go to glass it.
