What #lb. thrust is my Evinrude Scout trolling motor
LadyShar
I just bought a used Evinrude Scout trolling motor but I don't know what the #lb. thrust is. It's on a transom mount and has a foot control.<br />12/24v<br />Model#EBFX4A<br />Serial# H 2633810<br />Also, is there a way to wire it to have reverse also (a toggle switch or anything)? Any help would be appreciated. Thanks in advance.<br /><br />Wanted to also ask if there is a #lb. thrust difference between 12 or 24 volt?
OBJ
Re: What #lb. thrust is my Evinrude Scout trolling motor
Welcome to iboats LadyShar.<br /><br />Your Scout is a 90' year. From the parts list it's probably a high thrust model in the high 40' to 50's thrust range. I'll check when I get back to the shop and give a definate on that. Don't give a lot in the parts breakdown.<br /><br />You don't need a reverse....just spin the unit around till the prop faces forwards.<br /><br />Thrust difference is generally speaking half.<br /><br />I'll post ya' the particulars in a day or so unless one of the other guys can jump in here.<br /><br />Thanks!!
LadyShar
Thanks for the quick reply. Any and all info would be appreciated. The more I know about it, the easier it would be to get parts or for repair on it. I do know that I'm going to need a prop and some kind of receptacle of some sorts (It has a male three prong plug on it). Thanks again.
OBJ
OK, here's the specs.<br /><br />Static thrust.......31lbs.<br />Max Current Draw....29 amps<br />Shaft Length........48" with a 21" vertical adjustment.<br />Prop................8 3/4"X 4" PN 124709<br />Speeds.............6<br />Weight.............30.5lb.<br /><br />Need anything else....hollar.<br /><br />Jim
