what lower end oil do i need
brianis
so ive got a 63 mercury 500 winterizeing it first time doing lower unit oil what is supposed to go in it can i get some from walmart local boat shop says you need this 12 bucks a qt. but cant tell me what exactly it is and of coarse no boat shop close to me just wonderful walmart.
ufm82
Master Chief Petty Officer
Re: what lower end oil do i need
80-90 hypoid is the listed oil but Quicksilver Premium L/U oil is better than the 90w.
emckelvy
Wal-Mart should carry Sta-Lube or other aftermarket brand of Hi-Vis Marine-Grade gear oil which will lubricate your outboard's lower end just fine, for under $5/qt.
The $12/qt oil is Good Stuff, but it's rather overkill for your classic Merc.
Note that although you can use regular 'ol automotive gear oil in a pinch, marine-grade oil has special additives, formulated for the harsh marine environment.
HTH..........ed
joed
Once the oil is in the unit it's sealed. How does the "harsh marine environment" come into play?
