Re: what makes a tbi from a truck different then a marine setup?
Maybe only one person died because the regulations are doing their job...
You ever hear of the logical fallacy, "Post hoc ergo propter hoc"?
Tis is a REALLY dangerous assumption!!! As I stated earlier, same part number on an assembly doesn't necessarily mean same parts inside...
Yet your argument didn't stand up. Your "Part number" was in reference to the part number for the BLOCK, which WAS, in fact, the same part. Imagine THAT. Same part number; same part! The actual engine part number WAS NOT the same, was it? You kinda ignored that one...
The problem is not just a non-approved items ability not to START a fire, but also it's ability to withstand the effects of a fire started by something else...
*Yawn* I seriously doubt that a fuel injector is a weaker point than that flexible rubber hose between the tank and the engine... Or how about that GLASS bowl that sits on the bottom of the mechanical fuel pump? Glass doesn't stand up too well to heat either. But if it happens to be full of fuel, BOOM!
Now everybody within a 12 mile radius is going to be KILLED
Don't worry though, since it was a marine part, your insurance will cover it!
How do you know that the small metal collar around the injector head is not plastic in the automotive version... And that it is precisely that part that determines its suitability for marine use? You don't....
You can look at the part number! If they're the same part number, they're the same part! Even if it's NOT the same part number, you can do some common sense due dilligence.
"Is this part more likely to leak fuel?" YES/NO
"Is this part more likely to fail catistrophically?" YES/NO
"Is this part more likely to induce sparks to an area that sparks should no be? YES/NO
"Is this part more likely to hold large amounts of fuel in a central area, which could pose a significant risk of fire or explosion?" YES/NO
"Is my use of this part likely to interfere with basic safety functions of the boat"? YES/NO
"Is this part more likely to cause a pretentious fear-monger to get their panties in a bunch?" YES/NO
I'm sorry, I have to keep saying this... If it's not an approved marine use item, it has no place in a boat.... I don't care if the guy has a hundred years working with, designing, installing automotive gear...
No room for inovation, eh? It's clear that your mind is closed.
*Yawn*
It may well be as safe, or safer than marine approved... You, and he, don't KNOW that... The simple fact is... it's not marine approved! END OF STORY!!!!
Chris.............
So the only way you'll ever believe something is safe, is if your government puts a stamp on it, saying it's "safe".
What really gets me, is that even if it's SAFER, you'll use something that's NOT AS SAFE, because your government didn't explicitly state that it wasn't unsafe?
Wow!
Well over here in this little place called America, we were set up as what's known as a FREE COUNTRY. Not subject to kings, (or queens). Our entire legal system
was based on the presumption of being innocent until proven guilty, and something is LEGAL until proven illegal.
Thanks for ambulance chasers, and sheeple like yourself, we've swayed FAR from that in practice, in recent years, but the principals remain the same... We're losing it fast, but there are still a select few in this country, who are still capable of independent thought.
We don't need some outside "leadership" to dictate to us what thoughts are acceptable...
Some people, it would seem, do need that though. It's a sad sad commentary on today's world.
