What oil should I use in a tilt?
JDusza
Both being hydraulic, can use automobiley brake fluid?
Thanks,
J
GA_Boater
There is hydraulic fluid and there is hydraulic fluid. Brake fluid is not the right kind to use.
ATF or 30W motor oil, depending on what you have.
So - What are you working on?
brake fluid is hygroscopic (absorbs moisture) and not the best for anything marine.
as GA stated, most likely ATF.
jimmbo
If it is old style, pump in boat, the speced oil was 20w oil. The integral style was speced with ATF or power steering fluid
dpmsgeek
Old style was 10-20 or 10-30 depending on where you are. In Michigan I'm running 10w-30.
