matt167
- Joined
- Sep 27, 2012
- 4,292
Originally I was thinking of building a boat, decided to start small and build the 8' version of the Glen L/ Hankinson drift pram. I'v had the pieces cut out for about a month now, but the project sort of took a back seat when I got the Custom Craft. The other day, I wired the hull togther ( S&G construction ), and today I glassed much of the outside of the hull. Got the joints taped and such. I was going to hold off and get the recommended epoxy resins, but it's a cheap small boat and I wanted to get a little farther on it, so I want to WM and bought a gallon of Bondo resin, and a few packages of cloth, and a few packages of CSM.. Now I'm kinda stuck as to what primer/ paint to use. Is it safe to use a basic alky'd enamel with a primer and hardener? The boat will mainly be rowed around a local no motor lake, but I may add a 18-20# thrust troller and take it to a bit larger lake where the only non-local access is a DEC hand launch.. It will never be left in the water
