omc cobra guy
- Joined
- May 14, 2012
- 22
I'm working on a alpha one mr and I want to make sure the gear lash is set correctly. I know this much, the shaft has a needle bearing at the bottom and a taper roller bearing at the top with the taper being wider at the bottom of the bearing you would shim somewhere,after that I would only be guessing. Can someone explain the rest please?
