What's the proper compression for my motor
thunnus69
Just ran a compression test on the Evinrude 3.3 HP 1947-51 outboard I inherited. Both cylinders read 80#psi. Is this a good range? Would like to know before I continue on.
Thanks,
Joe
tashasdaddy
Re: What's the proper compression for my motor
sounds decent to me. i would continue.
freddyray21
that will run fine at that compression. Does it have a fuel valve that you use a screwdriver to open or does it have a knob. I am told 49 and older had the screw driver valve 50 and newer had a knob.
thunnus69
Thanks for the replies. Freddyray I'm not sure about the fuel valve. Haven't gotten that far yet. I am in the process of building two stands for the outbaords I plan to disect and hopefully get running. I ran out of screws for the stands and decided to tinker with one of the motors. I started with the easiest.
Take Care,
Joe
wbeaton
His motor is a 1948. The fuel shut off is (probably) a screw located at the rear of the motor accessed from underneth. 80 psi is fine.
The operator's manual should be in your email inbox.
hawkerjv
Hi,
My 3.3 HP has about the same compression. I found a parts listing of the motor that someone posted on http://www.aomci.org/ in the ask a member section. Someone on this site may be able to help also. My primer is shot (parts n/a) and I am trying to retrofit a primer from another small engine. Interesting carburation.
Jim in Dodgeville
thunnus69
Thanks again for all the replies. Thanks Jim for hooking me up with the Antique Outboard Club.
-Joe
hawkerjv
BTW-AOMCI.org is currently having technical difficulties.
Jim in Dodgeville
