pvanv
- Joined
- Apr 20, 2008
- 6,575
If compression comes up a lot with some oil, yes, rings are leaky. Compression testers are notoriously way off, so don't trust that number. Tohatsu America denied the warranty in under 5 years? That sounds wrong. I've seen them be very generous with warranty. The seriaql number will allow them to see date of manufacture, and I do expect the warranty is still in force. I recently had a customer with an EFI 8.8 who sold it, and it was confirmed tha the warranty is indeed trensferrable. Now then, if the carb ever sat for a couple of weeks with fuel in it, there is still the possibility of an issue there. Spray cleaners are not aggressive enough. Real carb dip overnight (I use a heated ultrasonic tank that holds over 3 gals of fluid for mine), followed by a meticulous and liberal blow out of all passages does work. The float valve needle, if funky, could cause flooding.
Start with the basics; When it doesn't want to start, but you haven't done something silly like over choking, pull the plugs and inspect. Wet is either flooded or no spark. Dry is no fuel. These 4/5/6 motors are nearly indestructible; I have some old 4A2s that look horrible, but periodic fuel and water pump servicing, and they run great. likely over 500 hours on some of them.
