Edge180
- Joined
- Sep 16, 2008
- 85
So as not to further hi-jack somoene else's thread I am posting my own as suggested to flush out my symptoms in hopes of fixing the problem myslef. Below is a quick run down of the equipment and service I know of:
2002 Sport Boat single axle trailer, break-away tongue, stock surge breaks, drum breaks, bearing buddys.
Since I purchased this boat + trailer used in '07 I've had a trailer shop service the brakes and bearings. Once in 09 and 10
In 2009 they repacked the bearings.
In 2010 they changed the brake lines and wheel cylinders due to the brakes sticking, repacked axle bearings, (the following is the list of parts installed) New 10-12" LH uni-servo wheel cyl, line fitting kit single axle, 10x2.25 premier RH surge brk and marine seal kit 2.33x1.68 UFP, BB only10"
(Shop recommended I replace master cylinder, but I declined repair at the time)
Symptoms: Passenger side BB caps have been popping off after relatively short pulls of 1 hour. On a recent long haul BB popped and grease boiling out.
My research:
Lifted passenger side tire to spin. Does not spin freely.
Lifted drivers side, spins a little more than passenger side, but still has mild resistance.
Checked oil level in master cylinder, looks to be okay. Color looks okay too.
Checked for "play" in lateral tire movement by pushing on top and bottom of passenger side tire. Tight.
Adjusted star "nut" inside break drum. No difference clicking up or down. Straightened the break-away toungue and pushed a little thin metal tab just behind where the hitch mounts (there are no places to insert screw drivers and lock-out surge break), went back to the tire; now it spins freely; no resistance whatsoever.
Master cylinder needs replacement, rebuild? I'll re-pack the bearings as I'm sure the passenger side is nearly empty.
My research:
