Where is the thermostat?
jerseyboy1983
I have a 1985 Evinrude 150 HP. I overheated really bad on sunday and along with the other problems it caused that i have to figure out and fix i want to replace the thermostat to cover all ends so it doesnt overheat again. Does anyone know where it is on the motor? Also ever since it overheated on Sunday i cant get it started again. I have spark but it wont fire. And for some reason the starter will turn the flywheel fast when i dont push the key in to choke it but as soon as i do push the choke in and rtry to start it the starter slows down. Any suggestions on why?
AlTn
Re: Where is the thermostat?
try marineengine.com for parts diagrams
ACAMS
Sounds like you have glazed the cylinders and have low/no compression.
That ain't gonna be pretty!
jerseyboy1983
I just did and it does not state the location. I will keep looking though.
jerseyboy1983
Ok great, thank you. Thats what i didnt know. What section to find it under. lol
jerseyboy1983
That sounds very bad. Is that why the starter slows down when i engage the choke?
jerseyboy1983
Damn, so the stupid Thermostat is behind the Valve cover? What idiot would design it to be there? lol
jerseyboy1983
Also, is there a way to get the glaze off without taking it apart and doing each CYL? Is there a fluid or spray i can inject into each CYL through the spark plug hole?
