Re: Where is Thermostat
why does step 32 in the Seloc Manual under L6 Assembling talk about "install the poppet valve, thermostat, and cover."?
Sounds like the wrong manual as the L4 115 does have a poppet and T-stat..
so I guess the 10-15 seconds it takes for the tattle-tale to pee is just how long it takes for the impeller to pump water up through there?
Yep.. takes that long to fill block up, cooling is a straight thru design but internal passage ways,plates and gaskets slow the flow down some to promote cooling.
I find it hard to believe these motors came with no way of knowing if your running hot. Am I missing something.
Nope.. That the way from the factory and reason for tattle tale, also no horn in box.
it also tells me that Mercury never intended this motor to be used during the winter time!
Hunters and fisherman have been using them for years in winter with no problems
I've heard these engines don't like to idle
The older distributor engines are more picky in their set up and idle suffers somewhat due to flexing drive belt,stiff/overgreased bearings in distributer,idle tube splits/cracks from age and vibration,wear on reed block labryth seals
