Looking for suggestions on where to find an impeller with these dimensions.
I have looked at ********** --http://www.***************/WestAdvisor/Impeller-Replacement-101-- on the Jabsco parts lookup and couldn't find close enough dimensions.
6 fins
through hole pin drive
width of impeller -- .535 inches <-- give or take a few thousands.
Outside diameter -- 1.60 inches <-- again give or take a few thousands.
Inside diameter (bore) -- 0.40 inches
The impeller is for a 1978 Spirit (Suzuki) DT4D. When I look up parts it shows the impeller as being obsolete.
So, thought I would look and see if I can find a reasonable replacement.
And, while we are on the topic.
How much should an impeller flex when putting it back in the pump housing? Eyeballing the impeller I just put back in it seemed like the impeller diameter was about 1/16 inch larger diameter than the housing. <-- The rest of this story is a topic for a different post.
Thank you in advance for any suggestions.
6 fins
