Which 2 terminals for jumping start?
cheers731
My 92 Four Winns with 5.8L OMC and Corbra OD has developed intermittent starting problem. On the cold start, it requires extra gas to start. However, with the warm-up button depressed, starter will not turn with either lever move forward or reverse. The starter will turn when lever is dead in center. I read Don's "Adult only" and there is a way to jump start from the slave solenoid if I am strangulated on the water. I looked at mine and this is the only solenoid I can find which is attached to the circuit braker box. Could someone kindly show me which 2 ends to connect for a jump start?
Thanks,
Don S
Re: Which 2 terminals for jumping start?
Using your picture, if the solenoid works, just jumper from 1 to 4.
If the solenoid doesn't work, you have to jump 1 to 3. Will take a big cable to jump it.
Your engine doesn't have a slave solenoid, only the one you pictured. There is no starter solenoid on your starter.
attachment.php
cheers731
Thank you so much, Don. Yes, there is no solenoid on the starter, only a hump on the back.
