Which glue???
hoverman
putting my outdrive back on and manual says i need to install and glue rubber gasket inside bellhousing of transom bracket . which glue? is there a name for the rubber gasket? i have an alpha one 2nd gen outdrive. any help would be apprecaited
Don S
Re: Which glue???
The Merc bellows adhesive is what I have always used.
jtybt
Re: Which glue???
You talkin' about that big square 'O' ring for a merc? I think the manual said perfect seal which is the same as the OMC's and permabond non hardening gasket sealer.
Oops! Wrong drive. I didn't read good. Yeah, rubber cement.
bigskiohio
Re: Which glue???
i used black gasket adhesive on that and water oring and let them dry before installing outdrive.
cr2k
Re: Which glue???
We always use Gask-a-cinch (the can with the girl on it, which is why my wife sez we use it). Actually anything that will hold them in place during installation will work.
Fun Times
Re: Which glue???
This is what I like to use also, The brush at the end makes it kind of easy to use.:)
