Ok, remember in the winter when I told you guys I was gonna pull the 454 ci in my Chris-Craft Limited, and put in a warmed up 502 Mag ? Well, Im getting ready to pull the old motor, and I need to know which motor mount bolts to pull. Is it the single one on each side on the top of the stringer mount ? Or do I pull the two base bolts on each stringer mount ? I was told if I do it right, everything should line right back up because the blocks are the same. We are gonna still check it, but this will make it easier. Thanks.
