300mag-hunter
Thread starter- Joined
- Jun 21, 2009
- 8
Which thrust washer for turbo prop?
I've got a 2001 3cyl Johnson 70hp w/ 13 spline prop shaft. I'm wanting to mount a 13 1/4 x 18 Turbo prop.
Only markings on the prop are inside the rear of the hub "TURBO" & "013 1/4 x 18"
The problem is that my factory thrust washer doesn't fit inside the center of the Turbo prop & the prop sits back too far to use the nylon washer & brass nut.
Any help would be greatly appreciated. I called Turbo (now Yamaha) & they were not any help.
The center recessed part of the the Turbo prop has a diameter OD 1.45", my factory thrust washer is 2.24"
Thanks.
http://imageshack.us/a/img903/8124/8phufC.jpg
Thanks.
