Which thrust washer for Turbo prop?
Which thrust washer for turbo prop?
I've got a 2001 3cyl Johnson 70hp w/ 13 spline prop shaft. I'm wanting to mount a 13 1/4 x 18 Turbo prop.
Only markings on the prop are inside the rear of the hub "TURBO" & "013 1/4 x 18"
The problem is that my factory thrust washer doesn't fit inside the center of the Turbo prop & the prop sits back too far to use the nylon washer & brass nut.
Any help would be greatly appreciated. I called Turbo (now Yamaha) & they were not any help.
The center recessed part of the the Turbo prop has a diameter OD 1.45", my factory thrust washer is 2.24"
Thanks.
http://imageshack.us/a/img903/8124/8phufC.jpg
Texasmark
Look up your prop on this site as props are sold here. If you find it, you may also see some amenities like the correct thrust washer which you can purchase advertised where the prop is displayed. Some props have the extras some are just the props. Good luck. If no luck, contact iboats and see if they can help you or go to Turbo themselves.
