kilapapipa
- Joined
- Jul 18, 2009
- 19
Purchased a used OMC 800. Put it on, tested with earmuffs. Noticed the steering was backwards so I researched and found out about 2 diff worm gears. I elected to rotate my steering and it worked so out to the lake we go today and put it in reverse to leave the dock only to have the boat go forward. This is laughable now. What will be the 3rd thing? We were able to test the drive and everything was good except I felt weird using the shifter in the opposite direction.
We couldn't have screwed up the connection to the shifter behind the motor could we have? I am thinking more like it is at the other end. Can we drop the lower unit and switch the wires under the plate? The long and short on the top end only went in one way.
