all duck'd up
- Joined
- Oct 20, 2011
- 166
Re: why wont it go FASTER!!!
just being curious because i dont know of anyone around my area with a 15 johnson like mine; and 32 mph would be the ultimate killer of my friends boat. can you tell me a few things about your motor?
1. spark-plug (brand and number on the side)? so that i can be sure why they are messing-up
2. how do you mix your oil 2.6 oz to a gal or 3.2? and what type of oil synthetic or not?
3. what hole do you have your tilt pin in?
4. do you know the size and pitch of your prop?
5. when you hit 32 what all was in the boat? fishing stuff, hunting stuff, battery/troller motor... or was it empty?
If that lever is pulled up toward you it makes the motor tilt up. If it is down then it locks the motor. If you pull up on the motor and flip the switch down then it does put the motor in shallow water drive but only if you are pulling the motor up. It does not matter what gear it is in. To get the motor tilt, take it off shallow water drive and let it drop all the way down. The switch should then go down and lock the motor. Simply pull the switch up to get the motor to tilt. I hope I am making sense.
View attachment 129844 Sorry but this is the best pic I have of it. My Duracraft is a 1970 model so it might be a bit lighter then yours.
