Re: will pl work for transom
Both methods are used here. Depends on who you ask, but both will work. I prefer to use polyester resin and mat because I believe it leaves less voids than PL alone. (depends on how well you get it clamped)
I recommend that if you use PL, make sure you spread it evenly with a notched trowel. A simple S-bead is not enough in my book. It may bond together but it may also leave voids. In my view resin and mat are better because you get an even coat of your "glue" over the complete surface. As long as you roll all of the bubbles out of the mat before you put it together, and clamp it well with weight or screws, voids will be minimized.
(make sure you pre-wet the bare wood with resin and let it tack before you assemble)
I also recommend, regardless of how you glue it in, dont go crazy tight with the clamps. Just tight enough for good ooze out of goop. If you go too tight you can distort the surface and your engine mount wont sit flat. You need to keep the outside surface as true and flat as you can.
