Mark42
- Joined
- Oct 8, 2003
- 9,334
Re: Will Tachometer work if Stator is bad?
It uses a Blocking Diode. I was able to test it, and it passes OK. Thanks for posting that info about diodes, I didn't know they came in different flavors.
Faztbullet, thanks for posting that test. I will do it tomorrow after Church. Will keep plugging away at this until the culprit part is identified.
Once again, the motor went into SLOW mode (or a good simulation of slow, HA!), This time I disconnected the temp senders (both) turned off ignition, and started again. IT MADE NO DIFFERENCE!!!! Still ran bad. So I bring boat home. By later afternoon, its cool and starts and runs smooth on the hose. So I intentionally ground the temp circuit, and the System Check temp light went on, the horn sounded for about 30 seconds, and the motor ran NORMAL!!! I thought it would instantly start running crummy, but there was no change. Although grounding the white/black temp wire does kick down the idle as the power pack thinks the motor is warmed up.
I'm beginning to think that the power pack may be bad, because when the motor starts breaking up and running bad, NO system check lights come on, and no horn sounds. When I test the temp circuit by grounding the tan wire, the horn sounds and temp light comes on. So its not a " bad temp sender is kicking the motor into SLOW mode." problem.
I did remove the coils, power pack and optical sensor cover to check all the connections and ensure nothing was obviously shorted. Cleaned the contacts and ground lugs with a course stainless steel scrub pad and reassembled. Everything looks good in this area, but it made no difference in the run test.
Also did a compression test and got 145psi on all 4 cylinders, although i think my gauge reads on the low side. At least all the cylinders are the same, and plugs look the same.
I'll do the regulator tests and let you know how it goes.
Yep, diodes will only pass current in one direction. If you have a multimeter put it in continuity mode. Put the meter probes on the diode leads. It may show open or shorted. If you switch the leads it should be the exact opposite. In otherwords, shorted one way and open the other. If it happens to be a zenier diode (small clear looking thing) it will pass current in either direction but at different voltages. They're a litte harder to troubleshoot with a basic ohm meter. You need to have one with the diode setting.
If the standard diode shows continuity regardless of how the probes are hooked up then it's shorted. If it shows no continuity in either direction then it's open.
The thing most overlooked on this post is the rectifier/regulator has a seperate output for tach signal. The rectifier/regulator can be good and tach sender signal side fail resulting in no or erratic tach operation. With battery voltage jumping around as you posted it possible that the rectifier/regulator has failed and causing stator to overheat,this will cause a miss as pack is not getting correct voltage from charge coils and the charge windings supply voltage for the battery charging. Here is how to bench test the rectifier....
Diode plate check: Test the forward diodes between the two yellow wires and the red wire just like you would on a regular rectifier. You should get a reading one way but not the other. Check the resistance from each of the yellow wires to case ground, you should have a high reading, typically in the M range. The red wire should not read to
ground or show a very high reading, 25M ohms or more.
B) Tachometer Circuit: Check the ohms resistance between the gray wire and engine ground. You should read approximately 10K (10,000) ohms. Gray to red, and gray to the yellow wires should be a high reading, usually in the M range.
