N2outboards
Thread starter- Joined
- Apr 11, 2010
- 87
poly strap... There are VERY few situations where that isn't the best option...
I think you will find that even vehicle mounted winches will be going to poly rope from the manufacturer over the next few years, it is far and away safer then wire rope, when we were competing in rockcrawling contests they made it mandatory to run the poly rope and I have to tell you it was great so I can firmly tell you I would use poly rope not wire rope
2" wide strap, it stronger then cable!
stronger than metal cable... 3/8th amsteel poly cable is around 18,000 pounds breaking strength.
http://www.amsteelblue.com/item.cfm?itemid=44866
$152I would think you could get a whole winch and strap for that price, (unless you needed an 18K# cable on your winch)
Notice i've modified for a positive free spool, i've streched across a spring whereby i can tuck under the pawl beneath a spring to give "freespool". Drilled holes on both sides of the spool and rigged a spring in between.
