Hey everyone, I completed my winterization today for the first time on my own and had a couple questions. I live in Ohio, so the weather can get very cold here. I completed last year's winterization along with the help of someone. We replaced the lower unit lube and impeller.
I didn't replace the lower unit lube this year because I only got the boat out 4 times this year :-( I plan on doing new gear lube for sure next year, but I think I will be okay with only 4 trips on this lower unit lube.
I read many posts here to help and they have all been great! I am 90% sure I want to fill the engine with RV anti-freeze. I think I want to do it just because it will be stored in a non-climate controlled large barn. I have already drained the engine block and manifold. From what I gather, I should buy RV anti-freeze. Questions:
1) Do I use this 100% or do I need to mix 50/50 with water?
2) Then I just disconnect hoses and pour the anti-freeze down the hoses till it starts coming out of the drain holes? I am thinking that I need to pour AF down hoses number 1,2,3 and 4 in the attached picture? Can someone please confirm for me?
Also, I didn't take the spark plugs off and spray them and the plug hole with fogging oil. Is this important, should I do this? How often is it recommended to change spark plugs? Every year?
