winterizing 4.3 gl 1997 ...
ceasarea
I had the boat professionally winterized...Found a bag with 2 brass threaded plugs...with a note to reinstall them in the spring before i start the boat...Is that normal to leave them out? I wonder where they go....i assume one on each side of the block. Thanks for your help.
Bt Doctur
Re: winterizing 4.3 gl 1997 ...
Guessing there for the block drains,one in each side.
ceasarea
I guess they are cheap to buy new ones....they are getting old looking . I will have to look to see where they are on the motor...near bottom ?
Bt Doctur
about the center of the motor just above the oil pan
Bt Doctur
Yes, only the blue plastic ones use a O ring.
