Re: wiring up trim/tilt sending units
Replacing my oem units with Sierra aftermarket . I don't have any wiring remaining to go by. From reading the other threads, i take it the trim gauge has the male - female ends, and the trim limit the two male bullet ends. Beyond that I am lost. Here is what i see in the vicinity!
Spot on... Now connect one of the the trim gauge sender wires to the brown/white and the other to ground... You'll probably find that the brown/white with the ring terminal goes onto a terminal block somewhere. In the kit (from memory) should be a very short length of wire with a bullet on one end and a ring on the other. Put that on the terminal block with that brown/white wire, or just chop the ring off and put a bullet on it...
The trim limit switch wires go the trim pump harness connector bullets with nothing in them, one should be purple, the other blue...
Chris.....
P.S. Don and Bond-o are just being picky (and rightly so) about asking for the engine details... I can see enough in the photos, but in future, ALWAYS tell us what you're working on...
And Don's dead right about that shift interrupt switch... Get it sorted!
