won't run with cowl on.
weldbilt17
I have a 1975 evinrude 25hp that runs great with the cowl off but when it is put on it bogs the motor down and it dies. I have checked for blockage and found nothing. Anyone know what this is,THANKS
Cricket Too
Re: won't run with cowl on.
Check to make sure the cover latches aren't hitting and interfering with the plug wires. Just a thought.
I had a mis on one cylinder with the cowl on, but when I took it off it went away. Then I noticed that when I latched the port latch the miss would start, when I would un-latch it the miss would stop. Turned out the latch was pressing against one of the plug wires and shorting it. I just re-routed the plug wire and it solved the problem.
kenmyfam
Could be either but I am leaning toward the exhaust leak.
tashasdaddy
base plate gasket, exhaust leank, they don't like dirty air.
weldbilt17
Thanks I will check that area to make sure.
weldbilt17
Thanks for the info I will check it for leaks.
weldbilt17
Thanks Tashasdadddy, I'll check the gasket for signs of a leak.
