Re: Work Begins Soon
My hull-bottom tube I cut to only about an inch and drilled 3/16 weep holes on the bottom so as little water as possible would linger.
Hi Mark - I'm definitely going to install them before I pour the Seacast. I think I'm going to use 5200 and hope that the Seacast forms a good enough seal to prevent leaks. I'm not sure I understand where you drilled the 3/16" holes though.
On to the motor - I finally was able to get the upper mounting pin out of the tilt assist cylinder. Turns out that the previous owner used a different sized pin that was too big. Instead of getting the right sized pin, he just hammered it in!
Whatever, it's out now!
I then put a wanted ad on craigslist for a used cylinder and associated hardware and got a response from a really cool guy in Richmond that had just installed power t/t on his 50hp. He sold me the cylinder, cables, and all mounting hardware he took off of his for $40! The next cheapest one I found was $270 and was sold "as is". Anyway, I got it home and had it installed in 15 minutes. Now the Westfield's power is ready to be installed, so I have no more excuses not to finish the transom.
Oh well, here are some pictures of the "n"used parts installed and one of the old broken parts.
BOB
