Re: Working on Mercruiser 120, where to start?
I was gonna rebuild the distributor but it looks like it was just done,
depends on what ya mean by rebuild. if ya mean R&R points, rotor, capacitor, and cap by all means, R&R them. i do this as yearly pm. every spring. if you mean rebuild as in getting new bushings i'd see how it runs first, if ya can see dwell variation on your dwell meter or ya can't get it to run right. i'd take it to a dist. shop and have it tested on accurate machines.
ya might take the plate that the points mount to off and have a look at the centrifugl advance weights and springs, lub them, make sure they move free. you can kinda test them by turning the rotor when the engine is stopped. you should be able to turn the rotor one way or the other, can't remember which way and then after turned it should spring back to it's original position. of course set dwell and timing after R&Ring the points. dwell effects timing.
Second I found some "stuff" sitting on the bottom way in the back. One is a bilge pump, and the other is.. well i have no idea.
is your blower intact? your bilge blower, aristocrafts have odd ones. a squirl cage blower. this is the fore view.
the blower motor is on the back side of where the hose is attached to it. i think that motor in your bilge is the blower motor that's disassembled itself from the squirl cage? this also answers your third question. the blower hose goes into that hole in your deck. from that hole it goes into the ski/fish locker. it's the hole ya see on the inside of the ski locker thats at the aft starborad side of it. out of the ski locker the hole goes out the aft end of the ski locker back into the bilge. if you can call it that for us.
your bilge pump shouldn't need water to operate. unless it has a float switch. if it has a float switch it does need to have water to float it or you need to manually operate it up to simulate water in the bilge. fwiw, my bilge pump is not the automatic type. ya turn it on on the dash and it's totally controlled there. on or off. i'm not familar with your pump. you need to find out what variety it is. auto or manual. looks kinda dirty. take it out if you can and clean it up and see how it works. there very simple pumps. i had to clean mine all up when i got mine too. it was filthy... and not working proper. cleaned it works just dandy now..
just another pic of the blower area..
