Beefer
- Joined
- Aug 4, 2008
- 1,737
Most, if not all of us, know what the recommended rpm's at WOT is or should be on our boat, based on either the label on the motor, or the owner's manual/user's guide. Mine is 4400-4800.
My question is this; 4400-4800 based on what? What prop were they using? Right now I'm running 4100 @ wot, with a 19pitch prop. I know the prop is not the original, and I don't know what the original prop pitch was. Do I just drop down my pitch, and assume nothing else is causing the lower rpm's? As far as I and my mechanic can tell, all other parameters are correct for my engine (compression, dwell, timing, etc.).
Since different boats have different weights and characteristics, do the individual manufacturers adjust prop pitch to whatever is necessary to get the boat/motor combo operating in the proper range?
So how do we know what our recommended rpm's at wot are based on, if we aren't the original owners? Makes me wonder how many sick engines are out there running with the wrong prop to make the rpm's fall in the recommended range.
