lovemywife
- Joined
- Aug 13, 2009
- 39
First it is a 1985 Evinrude XP150 24 gal installed tank.Okay what I have done so far to wake this motor that has been sleeping for about 1 1/2 years. Motor ran ruff before I did anything. Removed tank cleaned it out and checked/replaced all lines that were in need. New plugs and plug wires, ran motor did the de-carb as described here with seafoam, still ran ruff. Checked for spark with a timing light strobe type. Good on starboard side nothing on port side I guess that would be cylenders 1-3-5. Removed flywheel to check stator in doing so I found a magnet loose only being held there by magmatisem, re-epoxy and replaced wheel still no spark port side. Back to the stator looks like it had some slight melting on the left wraping (dont what to call it) in front there are two that look different than the others, the left one.
Any suggestions I know I need to get a stator or I think I do. So help looking for advise. What to do next bite the bullet and lay down the green for stator or should I check something else.
Thanks Greg
Thanks Greg
