Yamaha 20 will not shut off
rcgt78
Hi there!<br /><br />I have some electrical problems with my <br />Yamaha 20 -87. The engine doesn't shut off<br />by turning the key switch or pulling out<br />the emergency stop. The only way is to <br />choke the engine and wait until it stops.<br />Starting the engine from the remote control <br />works great.<br /><br />Are there any good ideas <br />of how to solve the problem?<br /><br /><br />Best regards,<br />Robbi
Ray Neudecker
Re: Yamaha 20 will not shut off
You have lost the ground connection to those switches. Grounding the ignition is how they work.
rodbolt
hello<br /> make sure the white wire near the CDI is not unplugged and that the black ground wire is attached to the block or head. sometimes after service or vibration they will be loose.. white from the CDI box to earth kills it.
rcgt78
Thanks for your advice! <br /><br />I checked and cleaned all cables and connections.<br />I have to connect the remote control and battery <br />in order to check if everything works. For the moment I have the lower unit for service.<br /><br />Robbi
rcgt78
Hello again,<br /><br />Hi have still problems with engine shut off.<br /><br />Checked all wires in both engine and remote control. Think I should try to measure if white is grounded when shutting off.<br /><br />What else could cause the problem? Faulty CDI? How do I know if it's the CDI that doesn't work?<br /><br />Robbi
rcgt78
Found the problem!<br /><br />Cable connection between engine and remote control was causing the problem. I should have checked it first but I missed it. <br /><br />Robbi
